It's been done and redone, and yes it works.I believe you can modify a non dash board with a crystal swap. I am not sure but I may try this as a way to not have to pay for the premium of the dash.
yeah it’s a pretty easy swap if you know how to solder/desolder.I believe you can modify a non dash board with a crystal swap. I am not sure but I may try this as a way to not have to pay for the premium of the dash.
Perhaps the multi itself will have a DFO onboard that can bypass the original oscillator on the A board and select the correct frequency on a per game basis?Farnell has 12MHz crystal oscillators, I'm going to test this one soon: https://es.farnell.com/qantek-techn...tt/oscilador-12mhz-20-8mm-x-13-2mm/dp/2508716
I wonder if this will be needed for the multi, or some solution like a dual frequency oscillator will be the way to go.
On my version (Aje french one), only CPS1.5 boots are supported. Hope you'll be able to integrate original ones on your multi.I think it's time for small update as we are moving forward on this project.
The Multi PCB has as usual ( similarly to CPS2 ), a microSD Slot, LCD display and mounts in place of the B Board. All games are supported natively without modification. One of the features....and here comes a good suprise, the multi includes the C board on it! No need for C board with this multi.
We are exploring, but that's still in beta phase ( don't be later surprised if we say that we won't do it ), we are trying for the multi to have natively support for other types of sound, starting by letter Q![]()
this one works.I can confirm that the farnell 12MHz oscillator I linked before doesn't work with my short A board. When powering on it gives a black screen.
I have put the 10MHz back and it worked. Then the 12MHz again, didn't work. I put the 10MHz again and it works. Same soldering (I have used a socket).
You came to the right place, it's full of information over here.oh ? you can change A-board from 10 to 12 Mhz ?
good to knowi wasnt aware.
already learned more in my first month here then in 3 years on my own about arcade. lolYou came to the right place, it's full of information over here.oh ? you can change A-board from 10 to 12 Mhz ?
you aint lying same here lol, love this forum.already learned more in my first month here then in 3 years on my own about arcade. lol
Before they go higher in price.Did you verify that the oscillator was working i.e. with a scope ?I can confirm that the farnell 12MHz oscillator I linked before doesn't work with my short A board. When powering on it gives a black screen.
If all games are supported natively without modification, does that mean any A board will run all games on either frequency? I picked up a Dash Hyper Fighting boardI think it's time for small update as we are moving forward on this project.
/is there any more available where you got your A board from ?If all games are supported natively without modification, does that mean any A board will run all games on either frequency? I picked up a Dash Hyper Fighting board/
Thanks for all the incredible work into this Darksoft!
