Official Interest list for Namco NA System Multi by Hammy (PCB design by Caius Arcade Repairs & Engineering)
Mine's not here yet, but where was the link for the EPROM data?
I don't think any of the USA stuff has arrived yet?
The roms are floating around but the PRG0's roms may not be "100% final" at this stage.
As feedback comes in things get tweaked.
Edit;
Good news, ram has arrived so we can move down the list again!
Edit;
Nothing yet, but stuff is moving slow all over the world, so no worries yet.
International shipping is just super slow through regular post office. FedEx, UPS, DHL, although you can basically have things next day, are charging ridiculous prices.
USPS delivers! So beautiful!!
Just in case the DIY-ers need a list:
1xConnector - Omron XC5B-6421
2x 74F373 - TTL35, TTL15
4x 74F244 - TTL30, TTL20, TTL10, TTL0
4x 74F157 - U1, U2, U3, U4
1x 74HC4060 - RNG1
1x 10K OHM 5SIP (e.g. Bourns 4605X-101-103LF‎) - RN1
1x AT28C256-15PU - RAM
40x 0.1uF 0805 ceramic decoupling caps (maybe not exactly 40, I didn't count)
13x 42pin sockets
1x 28pin wide socket
4x 20pin narrow sockets for the GALs
4x GAL16v8 (but I'm going to try some ATF16V8B-15PU soon)
1x 4 position dip switch e.g. Grayhill 76SB04T
Jumpers - all "non arrow" i.e. pads 2&3
Pins 31+32 are bridged on the Clone outline
Pins 10+11 are bridged on underside of the 74HC4060
If i goofed up something lmk and I'll edit this ;)
1x 74HC4060 - RNG1
13x 42pin sockets
@twistedsymphony, @Hammy can I be moved from the DIY to the assembled kit.
I don't have any problem to assemble the kit by myself but unfortunately I don't have all the parts I should have..
I've only:
- 1xConnector - Omron XC5B-6421
- 1x AT28C256-15PU - RAM
- 1x 28pin wide socket
- 2x 74F373N - TTL35, TTL15
- 4x 74F244N - TTL30, TTL20, TTL10, TTL0
- 4x 20pin narrow sockets for the GALs
- 1x 74HC4060 - RNG1 WRONG FORMAT (mine is SMD)
I chosed DIY because I was planning to make a big order from mouser but since I needed some components early I already made it a while ago and I'm not planning to order enough components to have free shipping from mouser so I'd prefer a full assemble kit or a full kit with components not assembled (I can assemble it bymyself with no problem with if needed).
I'm sorry for the trouble ;(
Thank you
I've only:
xxxx Parts
Thank you
No problem i can supply it with whatever parts required, if you have parts they can be removed from the kit and the kit price goes down for the parts taken out.
I've only:
I've marked you as "partially assembled", that way hammy knows to contact you about what he needs to send before shipping.
Can you mark me as 'partially assembled' the only thing I don't require is the EPROMs, everything else I need. Cheers
