FS [PRE-ORDERS] USB2DB15 and CS Ver. for JAMMA/NEO GEO
I'm really interested in getting one (or two) of these, what I want to use it for is to connect a Sega Astro City USB arcade stick to this SLG-260 supergun, and then to a CPS1 or CPS2 board. Do you have any experience of these superguns? I'm unsure how I would connect the kick harness.
https://www.aliexpress.com/item/1005004991216134.html
Hi, sorry for the delay on answer, i'm a bit busy right now and i don't see the forum so much :(
I don't have experience with this kind of supergun, only Minigun and HAS, but if this device support the same DB15 standard, will work fine.
May I know if USB2DB15 CS ver. would take the USB signal from KVM that connects to zero-deley arcade stick and a USB HID so I can use either anytime I want?
Hello friends! A few units of both the standard DB15 and CS Ver. are available for purchase. It's in stock and ready to ship!
Grab here
Hi @Raph_friend . I have two of the older models with the issue that @RGB found. I read his explanation and saw you posted a solution for the DIY implementation, but didn't understand whether I can fix it myself.
Is the fix to cut traces to 2SA1213 pins 2 and 3, and use bodge wires to swap the connections? Or would it be better to swap in a different part that matches the design expectation?
Please reach me on Discord so we can fix your units!
