Questions for Namco Noir owners
The led’s measure 3.5mm x 3.0mm, I removed one but they are very small and not looking forward to replacing any or all! 40 in total. I think an LED strip may be a better option.
That was also my primary idea. I wonder if would be possible tu use a led strip with the same female connector as the noir led panel. I have no access to a soldering station, so I’d need something “plug&play”.
Yes that’s what I used, a led strip. I tried a couple of alternate types because they are very bright.
Once I got it working I disconnected it as lights on cabs just annoy me, I always disconnect the marquee light on my cabs too.
Probably cheaper from aliexpress, loads of options here
https://www.aliexpress.com/af/led-s...strip&catId=0&initiative_id=SB_20200606000931
even RGB if you're into that
for brightness just rig up a PWM dimmer and adjust to how you want it, something like this (can be de-cased its a tiny pcb)
https://www.aliexpress.com/item/400...earchweb0_0,searchweb201602_,searchweb201603_
What type? The tekken 6 card or the banapass red/blue?
Hey, just checking in. I got your email and I’d like to buy the coin door. Did you get my email response?
