obitus1990
Sorry for the somewhat crappy picture, which is a capture of a video (on a bad monitor) sent to me by the board's seller prior to my purchasing the PCB - I did not notice this until I received it and observed this graphic problem in person.
If you look at Rastan's boots, you can see that they have vertical stripes, alternating pink and red. And if you look more closely, you can see vertical bars running through Rastan himself and his throne.
The candy-striped boots are also seen on the "continue" screen and after beating a level. It's way more noticeable in person versus what this photo shows. I don't notice any other areas of the game having these color/banding issues. I have another 100% working Rastan board, and, have also checked the game in MAME, and his boots are solid red. If I had not obtained a second 100% working one, I wouldn't have thought anything about it, because the game is otherwise perfectly playable and seems to function normally. Where on the board should I be looking to try and fix this?
Thanks!
Thanks!
