hardyhell
Have no device to flash. That’s what I meant with can’t
yea and there is also a simm test menu where you can perhaps see whats in. post pics of them here. if there is not enough Memory then Nothing works.The error you're getting about not enough simms is your problem. You will need x4 128mb and x2 64mb simms for Darksoft cart to work regardless of what game you're trying to load. If you're 100% sure you have enough memory, then remove the simms and clean them with 91% isopropyl and a qtip
I would recommend trying a different Supergun. Something that sticks to the Neo standard for buttons would be the best option, I don't think smallcab does.So !
I cleaned all the modules, reconfigured the reader to ID 0 (downgraded firmware to 4.6) and it worked. Well, no more "not enough memory" message. So it reads the sd, and I get to Region Select screen of Third Strike. Then I'm stuck because I got no button that's working...
So it has to do with the supergun (Smallcab Deluxe 1.6) right? Start is working cuz I can go in the special menu, but same, can't access any options there since not a single god forsaken button will work...
