Repo MVS Cart PCB Discussion
I decided to try and fit the PCM logic from furrtek into ATF1508, and it seems to fit. You'll need to use a 100 pin TQFP version, since the 84 pin PLCC is out of production and doesn't have enough I/O. The design as it stands requires 67 pins.
I've counted 66 I/Os and was planning to use PLCC84 devices (because I have them handy and you can install a socket either THT or SMT) plus a single gate LVC04. Miscount on my side?
Getting this to work with the PLCC84 version would be perfect for those reasons. It is quite possible that I made some mistake when setting up the project. It is a bit of a pity that they are out of production, but there should be still enough NOS for quite some time.
I would vote for TQFP over PLCC, not just for availability reasons but I find they're just far easier to (hand) solder.
A short discussion about modern MVS bootlegs brought the question of the availability of open-hardware cart boards.
Surprisingly a Google search returned a useful result: this thread ! What a coincidence.
If using a CPLD for PCM turns out to be a problem, an equivalent can be made with ~10 standard logic chips.
The schematic might be more useful than the HDL: https://github.com/furrtek/SiliconRE/blob/master/SNK/PCM/PCM_schematic.png
Same goes for NEO-ZMC and NEO-273. Space could be an issue however if the CHA board is already full of 27C322's.
  • Like
Reactions: nem
Ah indeed, I should have taken the time to read everything from the start ;)
This project seems to be heading for success. Good luck with the prototypes !
great work guyz, we definitely need a project like this for a brighter future on the neogeo homebrew dev front!
keep up the good work :)
if i can help testing stuff over prototypes let me know ;-)
