I redid everything from clean and now it is working thanks!
Nevermind spoke too soon. I am getting this error while tyring to compile PROG_CP1 with quartus. I am using arcade tv's custom menu.
EDIT: Spoke too soon. I forgot to use arcade tv's generated games.txt now its working
Info: *******************************************************************
Info: Running Quartus II 32-bit Analysis & Synthesis
Info: Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Web Edition
Info: Processing started: Sat Apr 06 18:07:16 2024
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off prog_cp1 -c prog_cp1
Warning (2002
: Parallel compilation is not licensed and has been disabled
Info (12021): Found 1 design units, including 1 entities, in source file /users/user/documents/vtxcart-main/cpld/mvs/prog_cp1/rtl/cp1_top.v
Info (12023): Found entity 1: cp1_top
Info (12127): Elaborating entity "cp1_top" for the top level hierarchy
Info (278001): Inferred 1 megafunctions from design logic
Info (278002): Inferred adder/subtractor megafunction ("lpm_add_sub") from the following logic: "Add0"
Info (12130): Elaborated megafunction instantiation "lpm_add_sub:Add0"
Info (12133): Instantiated megafunction "lpm_add_sub:Add0" with the following parameter:
Info (12134): Parameter "LPM_WIDTH" = "9"
Info (12134): Parameter "LPM_DIRECTION" = "ADD"
Info (12134): Parameter "LPM_REPRESENTATION" = "UNSIGNED"
Info (12134): Parameter "ONE_INPUT_IS_CONSTANT" = "NO"
Info (12131): Elaborated megafunction instantiation "lpm_add_sub:Add0|addcore:adder[1]", which is child of megafunction instantiation "lpm_add_sub:Add0"
Info (12131): Elaborated megafunction instantiation "lpm_add_sub:Add0|addcore:adder[1]|a_csnbuffer:oflow_node", which is child of megafunction instantiation "lpm_add_sub:Add0"
Info (12131): Elaborated megafunction instantiation "lpm_add_sub:Add0|addcore:adder[1]|a_csnbuffer:result_node", which is child of megafunction instantiation "lpm_add_sub:Add0"
Info (12131): Elaborated megafunction instantiation "lpm_add_sub:Add0|addcore:adder[0]", which is child of megafunction instantiation "lpm_add_sub:Add0"
Info (12131): Elaborated megafunction instantiation "lpm_add_sub:Add0|look_add:look_ahead_unit", which is child of megafunction instantiation "lpm_add_sub:Add0"
Info (12131): Elaborated megafunction instantiation "lpm_add_sub:Add0|altshift:result_ext_latency_ffs", which is child of megafunction instantiation "lpm_add_sub:Add0"
Info (12131): Elaborated megafunction instantiation "lpm_add_sub:Add0|altshift:carry_ext_latency_ffs", which is child of megafunction instantiation "lpm_add_sub:Add0"
Info (280013): Promoted pin-driven signal(s) to global signal
Info (280014): Promoted clock signal driven by pin "nPORTWEL" to global clock signal
Info (280015): Promoted clear signal driven by pin "nRESET" to global clear signal
Warning (21074): Design contains 6 input pin(s) that do not drive logic
Warning (15610): No output dependent on input pin "nPORTWEU"
Warning (15610): No output dependent on input pin "nROMOEL"
Warning (15610): No output dependent on input pin "nROMOEU"
Warning (15610): No output dependent on input pin "nAS"
Warning (15610): No output dependent on input pin "M68K_RW"
Warning (15610): No output dependent on input pin "nRESET2"
Info (21057): Implemented 310 device resources after synthesis - the final resource count might be different
Info (2105
: Implemented 30 input pins
Info (21059): Implemented 40 output pins
Info (21060): Implemented 24 bidirectional pins
Info (21063): Implemented 165 macrocells
Info (21073): Implemented 51 shareable expanders
Info: Quartus II 32-bit Analysis & Synthesis was successful. 0 errors, 8 warnings
Info: Peak virtual memory: 355 megabytes
Info: Processing ended: Sat Apr 06 18:07:18 2024
Info: Elapsed time: 00:00:02
Info: Total CPU time (on all processors): 00:00:01
Info: Running Quartus II 32-bit Fitter
Info: Processing started: Sat Apr 06 18:07:18 2024
Info: Command: quartus_fit --read_settings_files=off --write_settings_files=off prog_cp1 -c prog_cp1
Info: qfit2_default_script.tcl version: #1
Info: Project = prog_cp1
Info: Revision = prog_cp1
Warning (2002
Info (119006): Selected device EPM3256ATC144-10 for design "prog_cp1"
Error (163105): Cannot route source node "P_ADDR_ALL~38" of type max_mcell to destination node "lpm_add_sub:Add0|addcore:adder[0]|ps[2]~45" of type max_mcell
Error (163105): Cannot route source node "P_ADDR_ALL~38" of type max_mcell to destination node "lpm_add_sub:Add0|addcore:adder[0]|ps[2]~50" of type max_mcell
Error (163105): Cannot route source node "P_ADDR_ALL~38" of type max_mcell to destination node "lpm_add_sub:Add0|addcore:adder[0]|gn[2]~5" of type max_mcell
Error (163105): Cannot route source node "P_ADDR_ALL~38" of type max_mcell to destination node "lpm_add_sub:Add0|addcore:adder[0]|a_csnbuffer:result_node|sout_node[1]~47" of type max_mcell
Error (163105): Cannot route source node "P_ADDR_ALL~38" of type max_mcell to destination node "lpm_add_sub:Add0|addcore:adder[0]|a_csnbuffer:result_node|sout_node[1]~216" of type max_mcell
Error (163105): Cannot route source node "P_ADDR_ALL~38" of type max_mcell to destination node "lpm_add_sub:Add0|addcore:adder[0]|genr_node[0]~10" of type max_mcell
Error (163105): Cannot route source node "P_ADDR_ALL~38" of type max_mcell to destination node "lpm_add_sub:Add0|addcore:adder[0]|gc[1]~10" of type max_mcell
Error (163105): Cannot route source node "P_ADDR_ALL~38" of type max_mcell to destination node "lpm_add_sub:Add0|addcore:adder[0]|genr_node[0]~15" of type max_mcell
Error (163105): Cannot route source node "P_ADDR_ALL~38" of type max_mcell to destination node "lpm_add_sub:Add0|addcore:adder[0]|gc[1]~11" of type max_mcell
Error (163105): Cannot route source node "P_ADDR_ALL~38" of type max_mcell to destination node "lpm_add_sub:Add0|addcore:adder[0]|a_csnbuffer:result_node|sout_node[2]~67" of type max_sexp
Error (163105): Cannot route source node "P_ADDR_ALL~38" of type max_mcell to destination node "lpm_add_sub:Add0|addcore:adder[0]|a_csnbuffer:result_node|sout_node[2]~69" of type max_mcell
Error (163105): Cannot route source node "WideOr8~62" of type max_mcell to destination node "lpm_add_sub:Add0|addcore:adder[0]|gs[3]~3" of type max_mcell
Error (163105): Cannot route source node "WideOr8~62" of type max_mcell to destination node "WideOr8~65" of type max_mcell
Error (163105): Cannot route source node "WideOr8~62" of type max_mcell to destination node "lpm_add_sub:Add0|addcore:adder[0]|gn[3]~9" of type max_mcell
Error (163104): Can't place node "P_ADDR_ALL~41" of type max_mcell
Error (163104): Can't place node "P_ADDR_ALL~47" of type max_mcell
Error (163104): Can't place node "P_ADDR_ALL~53" of type max_mcell
Error (163104): Can't place node "WideOr8~81" of type max_mcell
Error (163000): Cannot find fit.
Error: Quartus II 32-bit Fitter was unsuccessful. 19 errors, 1 warning
Error: Peak virtual memory: 348 megabytes
Error: Processing ended: Sat Apr 06 18:07:19 2024
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
Error (293001): Quartus II Full Compilation was unsuccessful. 21 errors, 9 warnings
