I'll see if I can remove the resistors on the DC2VGA and put on the resistors for the Common attenuated sync levels. If that works, I'll put the post the gerber for the PCB.Congrats man, that looks pretty nice!![]()
It should. The amp is the same that is in the JAMMAizer. Arthrimus demonstrated he amped 31khz using JAMMAizer just fine.Does this work with 24khz output from JVS systems?
Hi RealMFnG, I wanted to ask you if you were ever able to upload the schematic of the final circuitI'll see if I can remove the resistors on the DC2VGA and put on the resistors for the Common attenuated sync levels. If that works, I'll put the post the gerber for the PCB.
