Tonybolony
Leeds , UK
I have a Disk And Keychip from a RE2 but when it boots it asks for USB device so i cant work out what it is.
253-5644-072BJ , closest match i found that ends in BJ was lets go jungle 3d
If you go into the SYSTEM TEST menu using the buttons on the ringedge, I think one of the options should show you the installed game name, or at least it's ID?
On your keychip there will be a 4 letter code at the bottom, followed by some other bits - like this:
SDEY ST JP
Can you tell me what that is, as then I can look up the game for you?
That one isn't online, not much about it at all!
If you goto SYSTEM TEST by pressing the test button on the front of the RE, and then navigate to Storage Information it will tell you the name of the game.
I'd be interested to hear what it is!
leave it with me , closest i noticed to the part no was lets go jungle 3d , but the RE is it not and this was in a RE2
Awesome!
Yeah unfortunately most of the game IDs will be fairly close to each other - they go up sequentially and being close to LGI3D doesn’t really suggest that the game has anything to do with LGI3D.
and next question is which dips change the resolution, to see if i can get it to work also
thankyou
