MetalliC
I'd suggest some part of DIMM volume must be reserved and can't be used, because as someone reported "Senko no Ronde New" won't work too, but it's size is about 254MB (0x0fe40000)
That was me, Senko no Ronde and Senko no Ronde SP both work fine but Senko no Ronde New Version was too large.I'd suggest some part of DIMM volume must be reserved and can't be used, because as someone reported "Senko no Ronde New" won't work too, but it's size is about 254MB (0x0fe40000)
as was said, you need to learn that means term "MB"I thought the file I had was well over 256MB
its not 1 000 000 bytes as you may thinkSo you are confirming that Rhythm Tengoku is 100% working?. found a 27c160
. burned Multi BIOS
. powered NAOMI2, no go, 3V3 is 3V1
. find a new PSU
. NAOMI2 powers up
. Insert 512 MB DIMM
. Inset CF card with Rhythm Tengoku
. Wait for memory check
. Wait for game load
. Board reset...
SUCCESS![]()
This eternal confusion is because marketing decided that they could sell "bigger hard-drives" by using 1000's instead of 1024.as was said, you need to learn that means term "MB"its not 1 000 000 bytes as you may thinkactually 256MB is 268435456 bytes
Yes! Even played a few of the mini-games, but as I said this is CF-Card which has a higher compatibility rate than netboot.So you are confirming that Rhythm Tengoku is 100% working?
Do you have the ability to test netboot? I'm waiting for some SIMMs to arrive to upgrade my DIMMs so I can't do any testing now.Yes! Even played a few of the mini-games, but as I said this is CF-Card which has a higher compatibility rate than netboot.
Sorry no, I need to dig up my netboot DIMM from somewhere in the garage to do that, after I got the CF-Card I never looked backDo you have the ability to test netboot? I'm waiting for some SIMMs to arrive to upgrade my DIMMs so I can't do any testing now.Yes! Even played a few of the mini-games, but as I said this is CF-Card which has a higher compatibility rate than netboot.
Yes I can test it tomorrow, just now I need to get some sleep!I edited my last post while you were typing I think.![]()
surely you custom cf reader had some bad wire connections. Happen to me everytime, got bad dupont cable.it loop with the loading game and checking memory for me
EDIT : After 3 or 4 loop , I have the error 21 : game note accpetable by main board
I need a japan bios ? It's a naomi 2
Do you have some references please ?Do you have the ability to test netboot? I'm waiting for some SIMMs to arrive to upgrade my DIMMs so I can't do any testing now.
I don't think. I played with many games with it with no problem. After RT , I played virtua golf with the same CF with no problem.surely you custom cf reader had some bad wire connections. Happen to me everytime, got bad dupont cable.Move your wires gently and try again
The early bird catches the wormCool. sleep tight.
Ok. Two confirmations of the same issue.The early bird catches the worm
Tested Toukon Retsuden 4 on 512 MB DIMM, NAOMI2, CF-Card. Game loads, gets to MPEG SoftDec and hangs.
