Wow thanks a lot. I think i actually have a XP sp2 cd somewhereYou need shutdown.exe from a Windows XP SP2 cd/install on the cd it will be in the i386 folder as SHUTDOWN.EX_ - run expand SHUTDOWN.EX_ C:\SHUTDOWN.EXE and copy the file onto the C: drive.
Once it's loaded and the registry is changed open a command prompt, run "ewfmgr c: commit" and then "shutdown /r". Once the system reboots the registry change should persist.
veritcal=1
So i added a config.ini file in e:\typexmulti and put "vertical=1" in it but raiden iv still starts up horizontal. What am i doing wrong?You do not need to modify the registry to get the vertical games to play vertically.
In each game's respective "TypeXMulti" folder, either create or modify the "config.ini" file.
Add the line
Code:veritcal=1
If you dont want to do it for each respective game, you can change it global in the "E:\TypeXMulti\config.ini"
I'm sorry I told you wrong. The "config.ini" folder would go in each games games respective "TypeXmulti" folder.So i added a config.ini file in e:\typexmulti and put "vertical=1" in it but raiden iv still starts up horizontal. What am i doing wrong?
