SEGA C2 UNO Multi Selector OLED
BladeZX
Ontario Canada
SegaC2 UNO Multi Selector
Here are the parts needed for the SegaC2 UNO multi selector
DescriptionQuantityPCB LocationDigikey Part No.Comment
Cap Cer 0.1uf 25V1C1BC1154CT-ND
Res 10K OHM 1/4W 5%5R1,R2,R3,R4,R510KQBK-ND
Switch Tactile SPST-NO 0.05A4EG1829-NDblack switches for up, down and select, attract
Switch Tactile SPST-NO 0.05A1EG1830-NDred switch for reset
CONN IC DIP SOCKET 14POS TIN23M5462-NDsockets for CD4066BE chips
CD4066BE chip2
296-2061-5-ND
Conn Header 8POS 2.54mm1
2057-PH2-08-UA-ND
connects to the C2 multi board - make sure pin 1 matches
CONN HEADER VERT 20POS 2.54MM22057-PH1-20-UA-NDYou will need to cut these for the pins that mount the board to the Arduino UNO and the 1 single pin for reset
OLED 128x641Amazon URL:
https://www.amazon.ca/Display-Commu...-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9tdGY&psc=1
This arduino UNO R3 board is the one I am using:
https://www.amazon.ca/gp/product/B01EWOE0UU/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Loading HEX to Arduino UNO
Here is the hex file needed to program the Arduino UNO:
SegaC2 UNO Selector Hex File
** Note: If download does not work, copy the link and paste into new window
You can use a program called XLoader
Connect the board to your computer via USB A and USB B cable
Launch XLoader
Choose the hex file to load
Make sure the device is Uno(ATmega328 )
It should find your board
Once set, click upload the program the UNO with the hex file
Attached are the gerber files
