BladeZX
Ontario Canada
SegaC2 UNO Multi Selector
Here are the parts needed for the SegaC2 UNO multi selector
DescriptionQuantityPCB LocationDigikey Part No.Comment
Cap Cer 0.1uf 25V1C1BC1154CT-ND
Res 10K OHM 1/4W 5%5R1,R2,R3,R4,R510KQBK-ND
Switch Tactile SPST-NO 0.05A4EG1829-NDblack switches for up, down and select, attract
Switch Tactile SPST-NO 0.05A1EG1830-NDred switch for reset
CONN IC DIP SOCKET 14POS TIN23M5462-NDsockets for CD4066BE chips
CD4066BE chip2
296-2061-5-ND
Conn Header 8POS 2.54mm1
2057-PH2-08-UA-ND
connects to the C2 multi board - make sure pin 1 matches
CONN HEADER VERT 20POS 2.54MM22057-PH1-20-UA-NDYou will need to cut these for the pins that mount the board to the Arduino UNO and the 1 single pin for reset
OLED 128x641Amazon URL:
https://www.amazon.ca/Display-Commu...-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9tdGY&psc=1
This arduino UNO R3 board is the one I am using:
https://www.amazon.ca/gp/product/B01EWOE0UU/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Loading HEX to Arduino UNO
Here is the hex file needed to program the Arduino UNO:
SegaC2 UNO Selector Hex File
** Note: If download does not work, copy the link and paste into new window
You can use a program called XLoader
Connect the board to your computer via USB A and USB B cable
Launch XLoader
Choose the hex file to load
Make sure the device is Uno(ATmega328 )
It should find your board
Once set, click upload the program the UNO with the hex file
Attached are the gerber files
  • segac2-selector-uno.zip
