Sega Daytona USA Mega Adapter Installation Help
Ok I'm back! So ive gotten my player 2 cabinet up and running successfully :) I am at the point where I can now link them together! I assume I need to connect both pc with a lan cable? How do I make them a pair?
Ok I will get myself a network switch give this a try this weekend. I will let you know how it goes!
So I got myself a new network switch and set it up. I think ive installed this mostly correct but I can't get the cabinets to link. I know the network is working because I transferred a picture from one pc to the other pc.
When I try to start Daytona the player 1 will boot but player 2 will not. If I unplug the player 2 LAN cable player 1 will just sit idle doing it's network checking. When I plug the cable in player 1 will boot. Player 2 never does and when I exit the game I get this error.
Here are the player 1 settings
When you say "set the network configuration of each emulator in the "Multi" folders of Racecab/Emulators folder of cab 2" How do I do that? I don't see what I should be doing. I think this is the step I am missing
The m2lagfix error you get can come from several things, I think it's easier to put Model 2 games aside for the moment, as M2lagfix patch is involved in addition to emulator and windows network config, and need Jumbo Frames to be enabled (read this : https://github.com/njz3/BFF_gameassets/tree/dd185d82ea3829033a4d99a65767b3a4739778cc/image_njz3 )
Focus on Supermodel or TeknoParrot first, it will be easier.
By "set the network configuration of each emulator in the "Multi" folders of Racecab/Emulators folder of cab 2" I mean opening to supermodel.ini in Supermodel LINK folder for example, and set the address of the current cab and the adress of the "other" cab, iirc.
For TP, launch TP, select a game and set the network properties in the GUI
