GadgetFreak
Yes, have sent you a PM with details.Hello! Are these still available?
Thank you
Thank you
)Thanks for replying, Dark. The problem is that it's really hard to find an 8751 around here. I thought I could get the game working just by flashing the three "unprotected" EPROMs from the CPU and leaving the 8751 free, or I even read on another forum that you could use a Z80 as a replacement. I tried both methods and neither worked. I'm going to have to get an Intel chip to replace it. My idea is still to turn it into Monster Land, but first I want it to work. I'm just starting out with this stuff, hehe! Cheers!Che, que bueno que viniste![]()
Si le falta el custom no te va a arrancar. Lo mejor que puedes hacer es conseguir in 8751 y grabarle el contenido del fichero "315-5151.ic74" que es el que va ahi.
La version unprotected usa estas 3 eproms.
ROM_LOAD( "epr-7152.ic90", 0x00000, 0x8000, CRC(fe49d83e) SHA1(307be38dd73ed37b275c1b464d266a752cb06132) )
ROM_LOAD( "epr-7153.ic91", 0x10000, 0x8000, CRC(48697666) SHA1(0f4c6db9558272f5ceb347e742b284474f18b707) )
ROM_LOAD( "epr-7154.ic92", 0x18000, 0x8000, CRC(56d6222a) SHA1(ad8ccf15fe7f1d6716f78490892da0167d79f67)
Cambialas y te deberia ir, busca en google. Si no lo encuentras mandame privado.
Hey, it's great that you stopped by![]()
If the custom chip is missing, it won't boot up. The best thing to do is get an 8751 and program it with the contents of the "315-5151.ic74" file, which is the one that goes there.
The unprotected version uses these 3 EPROMs:
Burn those 3 files in 3 eproms and it should work. Look for those specific files searching on Google. If you can't find them, send me a private message.
