alfa75
Hi everyone,
I’m currently working on a Taito Space Invaders Part II PCB and ran into a video issue that I hope someone here might recognize.
The problem is related to the grayscale/color output when using the adapter. For Player 1, all shades appear only in white — there are no grayscale levels, and therefore no proper color representation either. However, when switching to Player 2, everything appears correctly with proper grayscale and colors.
So in summary:
The PCB itself appears to have had previous repair work done on it, so it’s possible something in the video or intensity circuitry was modified earlier.
Has anyone encountered something similar on this board or on other Taito black & white / color-converted boards?
Could this be related to:
Thanks!
So in summary:
- Player 1: only white (no grayscale, no color)
- Player 2: normal image with correct grayscale/colors
- the intensity resistor ladder / DAC
- a faulty TTL in the video mixing section
- an issue with the adapter wiring
- or something in the player-select video path
Thanks!
