Brentradio
This is excellent news!
I will try this out ASAP...
Thank you Miisalo!
Thank you Miisalo!
It looks like they're all in the code, so I'd assume you can just make your changes in the sketch and reload it to the board. EDIT: Looks like it's all outlined in the manual, actually. I'm just now catching up on all thisthank you again!
Is there a way to rename games?
Currently the firmware is distributed only as source code, so you can follow the instructions in the manual linked in the first post how to edit, compile and update the selector. I haven't updated the manual for this new code but use this post as and example. You can change any name to anything as long as it's less than 50 characters long. There might be also some character limitations in the lcd library, so not all characters work.thank you again!
Unfortunately some soldering is normally needed, here is example installationDoes this require any soldering to install or does it use pins on the ST-V cart? I am no good with a soldering iron...I don't even have the reset fix in yet for the ST-V...I hard boot! :/
