FS Stereo + Kick Harness Add-on Boards (Everten)
Silly question and I'm assuming it is but wanted to make sure: the Atomiswave stereo solution is line level and safe to plug into a stereo amp, correct? I've been using an adapter harness up to this point and careful to not turn up the volume too much in my setup.
Correct. It uses the same circuit as all of my other boards.
I believe I am going to need one of these. Need to check if my STV is an A or B board. Stereo is a must!
Edit : Signed up for "Board A" restock E-Mail notificaion
Can you please make an adapter to convert 2RCA to 35mm audio jack as well? that would make it perfect for consoilzied setup (to use with PC speakers)
Most people use cable adapters. Are you asking for something different?
will this adapter fit perfectly with your board? I hope that the spacing between two RCA jack are standard so that this aliexpress adapter can be used
This
  • 3-5mm-Stereo-to-Dual-RCA-Audio-Adapter-Cable-3-5mm-Female-to-Dual-RCA-Male-Red-White-6-inch_c...jpeg
This will not work. The spacing on my kits is dependent on board layout and optimizing space for other components.
