I had another member here ask me to make him some power cables that will allow him to power his SUN PSUs directly from the wall without hacking up the original power connector. I ordered some parts to do it so I will offer it to other members as well. These are hand crimped.
Price is $25 each plus shipping.
I know there were a few different connectors used on the SUNs but this one is pretty common. It looks like this:
When the PSUs were originally installed in the cabs they were only grounded buy running the ground line of the cab to the case of the PSU. So if you request it I will include this cable that will plug directly into the existing power connector on your PSU in the empty middle pin. You then connect the other end to the case of the psu.
If your SUN psu uses a different connector then contact me. I can maybe make you a custom cable.
