"%SYSTEMROOT%" should be "%SYSTEMDRIVE%". Or just hardcode it to "C:\TypeXmulti\assets\ttxshell.exe".So I did the following:
This results in the following error message:
- Re-flashed drive with Dinomax image to SATA SSD drive
- Created new 3rd partition titled "GAMES", drive letter G:
- Copied the games to GAMES partition (copied a couple of shmups like Raiden III & IV)
- Copied Niko's multi files to both C: and D: partitions
- Removed "TypeXsys" directory
- Created new "Shell" Registry entry in: HKLM\X1\Microsoft\Windows\CurrentVersion\Run
- which points to: %SYSTEMROOT%\TypeXmulti\assets\ttsxhell.exe
I'll upload my registry tonight when I get home.Can you upload your registry file so I can take a look at it?
I had completely removed the "TypeXsys" directory, that should have taken care of the original "ttxshell.exe" no?Also you might try renaming the real "ttxshell.exe" in the C:\Windows, to something like "ttxshell.bak".
Nope, the real ttxshell.exe is in "C:\Windows", the launcher and game container are whats in "C:\TypeXsys".I'll upload my registry tonight when I get home.Can you upload your registry file so I can take a look at it?
I need this LOL , especially for TGM3 purposesSo I made two change:
Edited the path in the Registry to be the explicit path: "C:\TypeXmulti\assets\ttxshell.exe"
and renamed:
C:\Windows\system32\Ttxshell.exe
to
C:\Windows\system32\Ttxshell.bak
And we have....
Woohoo!
Nice, if you could supply a picture of the lid and hard disk type that would be sweet as well!Yes I can upload the Dinomax image. Will do so tonight and share a link.
I actually have a TX choice multi hdd and would like to get kof 98 UM running on it.. only issue is needing a PS/2 Keyboard to choose the game... any way around that or is there any solution to just using the jamma video feed from the TTX to be able to play it properly? was getting issues with the niko modified multi that @jugu provided@jugu any chance you can share that Dinomax image since it is undumped ?
If you share it it can be submitted to MAME for posterity.
I made a Type X multi years ago based on KOF 98.
What where the issues you where experiencing?I actually have a TX choice multi hdd and would like to get kof 98 UM running on it.. only issue is needing a PS/2 Keyboard to choose the game... any way around that or is there any solution to just using the jamma video feed from the TTX to be able to play it properly? was getting issues with the niko modified multi that @jugu provided@jugu any chance you can share that Dinomax image since it is undumped ?
When using the one Jugu had made the resolution was heavily discolored when connected to the TTX via the 31khz slot.. the games also didn't boot or would hang..What where the issues you where experiencing?I actually have a TX choice multi hdd and would like to get kof 98 UM running on it.. only issue is needing a PS/2 Keyboard to choose the game... any way around that or is there any solution to just using the jamma video feed from the TTX to be able to play it properly? was getting issues with the niko modified multi that @jugu provided@jugu any chance you can share that Dinomax image since it is undumped ?
interested to find out that as well, will any off the shelf 9600SE/GT work? Or does it have custom BIOS like TTX2?anyone knows if that 9600se has a custom bios?
in my x1 was original a 9600gt, with a 9600se i get a error msg when starting Multi menue....with the original 9600gt the error msg appears, too...
muti dosent care bout gpu bios so that means the base driver on the os is whats wrong, and dosent work for the GT model.anyone knows if that 9600se has a custom bios?
