Taito Vewlix Diamond Replica Project.
hursit
Turkey
Hello guys.
I finished my Custom Vewlix Diamond Edition Cabinet.
I made it by MDF. You can see the all images of the whole process.
The whole process is about 2 months. I didn't work full time.
I design it for PC and PS3 for now. But after Niko Release the Nesica Multi system, i will put my Taito Type X2 main board in the cabinet. And i will wire the all system for jamma.
For now Im just using it with Attract mode Fronted.
You can watch the video:
https://www.youtube.com/watch?v=5MU4wOEq8dQ&t=15s
First 3D Drawing.
Main Case
I draw the all Control Panel layout as Vector graphic with Adobe Illustrator.
More Wood job
Control Panel
Side Parts. Made by 2 MDF (18mm)
Its a small hole for the monitor bezel. It is sliding. It can be remove easily
Fake Nesica Card Reader :P :D
These are not MDF. It is wood.
Top Layer. I fiex 6 pieces of MDF then sanding :)
Monitor Bezel
All Finished before painting.
Lets paint it.
After Paint.
Marquee Arts And Side Arts and Control Panel Before printing.
After UV Print on the Plexi Glass Directly. ( Not Paper )
Lets Bring my home :P
Samsung 32" TV
Other staff
Metal part for control panel. I put it under the Plexi Glass. Metal is 1.2mm thick. And Plexi is 2.8mm
Hımm Not Bad
I covered the whole Marquee plexiglass glass with Car Glass Film.
Side Arts
Control Panel
Other arts :) for the instruction panels.
Speakers. (4pc)
Wiring buttons and joystick. I made it as a socket. It will be easy if i wanna change it.
Thats a PC/ps3 Controller.
And Finish 8o 8o
That came out great!!
It always amazes me what people can do with wood!
Just a thought:
Rewiring it for JAMMA doesn't make much sense for the Type X2 as it's JVS. I mean you could totally run something like a Capcom IO over JAMMA to the X2, but it seems like an unnecessary additional step if you're wiring from the ground up anyway.
If you're going to need a JVS I/O for the TTX2 anyway then why not a Capcom I/O?
I mean you can buy complete JAMMA harnesses that are nearly plug and play. Seems to me wiring a custom JVS harness would be the more time consuming option.
Great looking homemade Vewlix clone, how expensive approximately was it to construct?
Thanks for the info. But i already have full Taito system.
I have TX2 multi system with SSD and I have Capcom I/o Board.
And i have another Sega JVS I/o
I think i can make custom adapter for plug and play.
And if you realise that i already made another control panel for the Arcade systems with out Select And Home Button :)
Wow, at the top of the post I was totally not expecting it to turn out the way it did. You have great skills to plan and build that. Amazing! :thumbsup:
Wow, that really came out fantastic! Thanks for posting so many detailed pictures, they really show how much time and dedication went in to this project.
nice job, i see someone is running my ui :D , tho so elements appear broken not sure why. if i had to guess its the bug I found inside the animate module , and you just used the "theme" only install and not the full thing could be worng tho.
Its interesting. What kind of elements broken ?.
I think i just set it full. Or maybe i miss something.
And thank for that great theme :D
The game select area isn't functioning correctly
it should move akin to this.
yours the enlarge/shink commands, and the frame isnt moving.
Yeah you're right there is a problem
What is wrong do you think ?
or is there any latest version links or something ? I can try it again and i can re-set it.
Ie replace you animate folder, with the one out of the full install.
Top notch work! My profile pic is of the one I made so from experience I know you put a ton of work in to this!
