J
jassin000
The real issue is going to be getting that 60pin connector. Taito has the pcb adapter.... I think I'm going to go JAMMA kit and Capcom IO because I have all the parts right now and I hate DIMMs anyway.
Oh that's bad news I was hoping on buying a JAMMA kit soonThe real disappointment is Taito is out of JAMMA Kits, and Yugo says at this time it's out of production.
Should have given you a link, not easy to find if you don't know where to look@brizzo thanks! Yea that seems like something I should look into.
agree with pic, CVS2 game require 6 buttons per player (12 bits in total) but this JVS IO reports it have only 11, while in reality it supports more.
patch is done, you may drop some coins to Dumping Unionhope a patch could be found/made, I would happily donate Paypal funds.![]()
We've tested both versions of the Taito Vewlix JVS IO (the classic found in the F/C types and the new one with the L branding).How much did the earlier revision JVS IO’s report?
IIRC you'll need to trim down IDC connectors to fit and the pin shape isn't 100% correct either. (pins on these headers are wide and flat, not square)but from the photos it looks like standard 0.100" pitch IDC headers with ribbon cables would be compatible? They wouldn't work with the clip locks, but thats okay
I'll donate one of the old JVS io if anyone wants to find a way to dump and reflash it?proper solution will be fix this JVS IO firmware.
is there was any attempts to dump it ? Renesas HD64F2138 datasheet didn't mention any security fuses.
Can you post a quality photo of the MCU on the io board so we can see the full part number? Then I can answer if its a flashable part or notI'll donate one of the old JVS io if anyone wants to find a way to dump and reflash it?
