FrancoB
UK
Allows a range of Seimitsu joysticks to be fitted to a Taito Vewlix E3018350A control panel mount.
Files / more info uploaded [here].
Printed in PLA, 100% infill.
Unscrew the current mounting plate from your joystick and fit the adapter plate using the same screws. The joystick can be then screwed to the Vewlix CP mount using the standard M4 screws.
Compatible with the following joysticks:
LS-55
LS-55-01
LS-56
LS-56-01
LS-58
LS-58-01
LS-60
LS-60-01
LS-62-01
This won't fit the LS-32 or LS-40 sticks i'm guessing? i know it's not listed ubt I wasn't sure how different the pattern would be.
I just had a look at the dimensions of this model and the mounting holes are 40x40mm. LS-32 and LS-40 look to be 50x50mm so they won't fit this adapter plate.
I have got a LS-32 kicking around somewhere though so I'll dig it out and see if it's possible to make one for the LS-32/LS-40 too.
Franco, I had the Seimitsu plate already made based on their diagram. I am currently printing it now, so if it's good to go I will share it on printables so everyone can benefit from it.
so I don't know why, but the plate doesn't fit on my vewlix, the holes for top to bottom are short by about 10mm. i'm having it fixed to reprint now.
