xodaraP
You can remove it carefully with a flat screwdriver, it's socketed. The Z80 has the sticker on it and does not need to be replaced on your board.
:/There is no game using both Z80 and 68000 encryption.He only has to replace the 68000, the Z80 should be fine.And you have an encrypted 68k on that board you will need to replace too.
Ok cool do you have a link to where I can obtain one please?No. The bigger CPU is the 68k. You don't need a Z80, you need a 68k (FD1094 is the encrypted 68k)
Cheers. from (comment #87 of this theard) or hereOk cool do you have a link to where I can obtain one please?No. The bigger CPU is the 68k. You don't need a Z80, you need a 68k (FD1094 is the encrypted 68k)
Cheers,
That is one beautiful, clean edge connector. Thing looks brand new.is 68k encrypted soldered on MB or can I unplug it with flat screwdriver? where is the Z80 in my tetris MB plkease?
I am not located in the states at the moment. Living out in Korea and I am restricted to my camp. I depend on everything coming through the mail. The life of a Soldier quarantined in South Korea at the moment until further notice.It would, but why not buy locally?
https://www.ebay.com/itm/Motorola-M...877558?hash=item4da8776076:g:d-oAAOSwkA1eZD0O
arf...hope same for evrygame...Dip settings need to be changed per game.
Again dipswitches are hard wired…one question with multi 16b can we save dip switch set per games with electronic method? or change dip switch when change games?
it's seems for beat them all set is same (altered beast, shinobi, golden axe....)Again dipswitches are hard wired…Of course you could imagine all sort of messy solutions requiring to either altering the motherboard or game code.one question with multi 16b can we save dip switch set per games with electronic method? or change dip switch when change games?
