J
jassin000
I whipped up a homemade 8pin mini din to SCART cable for testing.
Using a ferrite bead and connecting only the following pins to reduce video noise (none present
This is what you are building inside the VLX machine, its essentially a JVS supergun (Jammafier+Jassifier+OSSC)...
Installed inside the L-AMI, or as I'm now calling it "tatelux" heh.
^ yes, same setup with two exceptions. First I’m running a Lindbergh psu and no step-down. Second with some sources (Taito x2, Ringedge) I target 720p with the ossc and let the monitor line-double from there. When the ossc pro is out I’ll switch to that for all scaling. I’m also keeping tabs on the other
