Hello
SO I came in early, still got to finish the Time Crisis 4 project and get both sides working, we are now happy we hot Player 2 working (PSU was going under volt)
I did some experiments with Player 1 hard drive and security key, found that Player 1 HDD was not booting but found that both security keys worked in Player 2 ( I think, not 100% on that now )
So, I got CloneZilla out and found I could not read anything on the working Player 2 sda original 40GB HDD disc (also found a alternative disk for now) and I was going to write out to another (or one of the same make)
I have read on here that 'dd' are possible, I am also aware that macos 'dd' is a program I could use but I need two USB>IDE cases.
Is there an easy way of duplication?
Included pictures to show the error message and that I am not doing anything bad.
I did attempt to clone to same drive, but the drive I had was ticking! so I tried other methods including making an image
Thanks
Dave
edit: Just been using Player 1 on same hard ware, so the dongle has the same TSF lower number but the upper number is different (presume serial number).
edit 2: Just noticed an ebay listing with a 80gb drive in a 256 ? mines a Samsung 40GB SP0411N ... does it matter?
Thanks
Dave
