When I power on my CPS2 w/ multi and after the post-game load reset, I see only a black screen. When selecting a game on the LCD, I see the flashing progress bar followed by a very brief "writing key" type message, finally ending with "now playing", which stays on.
Testing was done on a Blast City with 5.07v +/- 0.03 depending on load measured across CN9 pins 1 and 6.
Pictures of B board here:
https://imgur.com/a/XcK4PAN
Pictures of back of multi here:
https://imgur.com/a/beUaPbv
I recently received a CPS2 multi from the latest batch from Paradise Arcade along with a "DARKSOFT CPS2 PAL" (more on that in a little). The multi was received with all pins intact and unbent, and was installed without issue. I also tried removing and reinstalling the multi. The board connector board is oriented properly and a random sample of continuity tests confirm it is in correctly.
micro SD card is SanDisk Ultra 32G SD HC Class 10. Freshly formatted with the official SD card formatting tool.
I have properly wired the key flashing connector (I think I quadruple checked, at least). Given that the reset functionality seems to be working, its safe to assume at least SETUP2 is wired correctly. I have tested games with and without encryption keys.
My CPS2 was purchased a few years back as a suicided progear conversion. A and B board region is Asia (grey). The B board is a 93646B-7. I tested the game just before removing ROMs and installing the multi. The jumpers were already in the correct configuration for the multi, but I doublechecked continuity anyways to verify the proper configuration.
Regarding PAL3, I assume it is a G due to what I have read on various posts here. Not wanting to assume, though, I lifted pin 7 and wired to J17 and received a black screen on power-up as well as the post-flash reset. I also tested the boards original PAL3 to no avail.
Unmagnified visual inspection shows that flash chips and ARM chip have good soldering.
I'll be verifying with a microscope later tonight. Verified with microscope that all chips are properly soldered.
I really hope its something stupid I've missed. Thanks in advance for your help.
Another unrelated issue is that I am unable to close the top case of the B board even after removing the one post. The LCD connector is like 4-5mm too tall. I verified by removing the lcd and cable and closing the case. I am going to use an ultrasonic knife to cut the little protrusion off the top of the connector so the case can be closed. I was hoping to be able to fit the connector through the play count hole for external mounting, but the connector is just too big to fit.
