I've been wanting to do something like this for a long time as I've always found it annoying/tedious looking up IC pinout when repairing boards. I decided to give it a go a couple weeks ago. Its far enough along that its useful so I wanted to share. Its website based project that can provides quick and easy access to IC pinouts, IC truth tables, pin in/out direction, what pin(s) are viable for audio probing, etc.
You can see it in action here
https://uc-ic.mvs-scans.com/
An IC is just config file that gets rendered (svg) by the browser.
It currently has support for rendering DIP, SIP, PLCC and QFP packages, plus Edge Connectors (ie JAMMA/MVS). The details you see under the IC are in markdown (in the IC config file), which is also rendered by the browser.
Here is the github repo
https://github.com/jwestfall69/uc-ic/
There is no server side code, so you should just be able to checkout the repo to a webserver and it should just work. For my test webserver above I just have an hourly cronjob that does a git pull to keep it up to date with changes.
For my use case, I load it up on an old ipad and have it in front of my while working on a board.
This is still a work in progress. Aside from adding more ICs and maybe more renderers, I need to do a better job on the css/div/html mess in index.html and also write up docs going over adding new ICs configs.
