xodaraP
Legendary
Ahhh that makes sense. I’ll do a firmware upgrade then. Thank you for the info
It seems is out of stockAre these currently available? I'm still learning all about Superguns and whatnot and this seems like a must have.
Just circling back on this. Got the DB15 model and my Mak Supergun all hooked up. Thankfully I didn't buy a M/F DB15 cable cuz the UD-USB plugs right into the Mak. :p@YesAffinity, they are safe now (hardware updated to deal with the abuse). Thanks for the reminder that the warning is still on PAS. I'll have to bug them to update the description![]()
Yeah, you can use standard DB15 extensions.
-ud
Paradise Arcade Shop. They just happened to run out recently (both versions were in stock for a few months straight). I know they have some of the Screw Terminal version ready to put up on their site. I'll see about the DB15 version.I curious as to the best place to buy these in the US?
Great notice! @oneleaf86 i was wondering if a pc keyboard would work? could you try it if you have spare time?This means any controller that Cronusmax supports will work.
The Cronusmax supports Keyboard and Mouse so yes it definitely will work.Great notice! @oneleaf86 i was wondering if a pc keyboard would work? could you try it if you have spare time?This means any controller that Cronusmax supports will work.
Great, you know if has remap functions? have friends that would love to play street fighter 2 in my supergun setup with their keyboard.The Cronusmax supports Keyboard and Mouse so yes it definitely will work.
Not sure if this known or has been discovered but today I tested a Cronusmax Adapter with the Decoder and it works flawlessly!
First thing I tried was a 360 Controller with Wireless Adapter and it worked great!
If used with a USB Bluetooth Adapter you can use PS3, PS4, Wii and WiiU Controllers wirelessly.
Negative.
