UltraSean
I’ll take one as well
When you say dedicated ground for the audio, does this mean there is a ground loop isolator on-board or is it some other setup?• line audio has dedicated ground to eliminate ground noise (buzzing)
It means that the line audio has its own return path.When you say dedicated ground for the audio, does this mean there is a ground loop isolator on-board or is it some other setup?• line audio has dedicated ground to eliminate ground noise (buzzing)
