Yes, and I didnt bother to clean it, for that authentic used in an arcade and trashed about touch loloooh thats nice !
didnt know it had a shell![]()
Yes, all Varth's come with them from factory! There is a nice example on YAJ right now for only about $300.is there any way of buying such a beautiful case?
it's a vacuumformed part, you can reproduce it with a vacuum forming machine.Ah, I don't think it's feasible with plastic,
There are two versions of this case. one for the long A-board and one for the short A-Board. the top shell is the same in both versions it's only the bottom plate that's different. So the long-board version sticks out like that.Very cool, never seen that one. Is it shorter (the case) or does it look shorter because the PCB is longer?
Yeah but the sad part is that you'll probably have to pay for a prototype of the mold. Range price for creating a proto ... starting around 5.000$, just for making a mold.it's a vacuumformed part, you can reproduce it with a vacuum forming machine.
you're confusing vacuum forming with injection molding... Injection molding forms do indeed cost upward of $5000 because it has to be made out of metal with precision maching. Vacuum Forming mold making is much cheaper and can easily be done by hand out of wood or clay. Even easier if you have a part to make a template with you can just fill it with clay to make the mold. It's not expensive it's justs a matter of finding someone who has a big enough machine and making the mold.Yeah but the sad part is that you'll probably have to pay for a prototype of the mold. Range price for creating a proto ... starting around 5.000$, just for making a mold.
Unless you can provide them with a schematic of the piece you want to make.
I think you'd sell 100s of them, ONCE the CPS1 multi is done and out the door. That's really what people need a case for!aluminum cases can always be done.
making only one would end up quite pricy.
*~But~*
if any colors can do...with at least a few cases for more then one person...
+ someone can provide a pcb for me to test.
it's not totaly impossible to make something looking alike.
it shall be diferent but with similarities.
i could look into this after 3rd order is closed
if anyone is still interested by then![]()
(wich could take me some time since the paint oven needs to be changed in upcoming weeks)
Yeah probably best to wait until the CPS1 multi can be accommodated properly, then I expect they would sell very well.I think you'd sell 100s of them, ONCE the CPS1 multi is done and out the door. That's really what people need a case for!aluminum cases can always be done.
*~But~*
Well the CPS1 case i did previously is probably the most popular oneI think you'd sell 100s of them, ONCE the CPS1 multi is done and out the door. That's really what people need a case for!aluminum cases can always be done.
*~But~*
