@Jughead - that would possibly work if you used something like a pin header extension. You would need to make a longer JST PH >PH cable though as the included ones are just long enough to reach as 'stock'. The UFBs PCBs would sit higher inside the control panel though and I'm wanting to keep as much clearance as possible for components in the sub panel.
@notsonic - that's would work too. I imagine the pinout would be reversed but you could make another PH>PH cable with the pinout reversed on one end to suit. I'll probably never use the UFBs in anything else but having the connector on the bottom of the PCB might stop me using it in something else.
If it is an oversight I think the easiest thing would be just to replace the straight B6B-XH-A header with a right angle S6B-XH-A. The JST PH >PH cable can be used as is then.
I don't have any right angle S6B-XH-A in stock but I'll get some ordered from RS Components. I'm keen to do some other testing though so in the mean time I've added a straight B6B-XH-A to the underside of the Console IO as I have some of them to hand. TBH this could stay as is but I would rather do it properly and swap it out for a S6B-XH-A when possible.
