Someone Else
Thanks rewrite! Great advice again, and a pal from the start. I likely wouldn't even have my favorite cab otherwise.The switch in the rear is like a kill switch, nothing in the cab gets power if it's off.I hope that didn't hurt the PSU at all.
The panel lighting, look under/around the instruction glass when both halves of the control panel are open, it should be pretty obvious, I'm pretty sure it's on the right hand side.
The marquee light, IIRC, turn the cab around, remove the uppermost black panel, the one that shares the same curved shape as the white in the front. The light assembly is in there, beneath the marquee holder, and above the red "Vewlix" plastic.
The lights are AC, they're not attached to the PSU (or at least the marquee one is).
https://imgur.com/a/VPCVr
I appreciate the detailed pictures!
Side note: I used the front switch, but hopefully everything was okay for a few days.
