Vewlix rear fan replacement
Hi guys,
Just asking for some advice about the Vewlix fan arrangement.
I got my first Vewlix F recently which I have dismantled, washed piece by piece and mounted back upstairs.
https://www.arcade-projects.com/thr...your-recent-purchases-thread.1970/post-441542
I running a PC inside installed on a bespoke test bench and with a good CPU and GPU air cooler system.
https://www.arcade-projects.com/threads/ideal-pc-cases-for-arcade-pcs.18593/post-440179
My Vewlix came with 5 original fans: one 120mm at the bottom panel, two 60mm at the top behind the monitor frame and two 80mm inside the monitor frame. Of course, they are very noisy, so I am running just the two inside the monitor frame and I disconnected the others at the moment. Also, I have bought a replacement for the 120mm one and I am going to install it over the weekend.
1) Do I need all the fans operating, considering that the cab is not located in a free smoking game centre anymore and it won't operate for long sessions?
2) Will just the 120mm fan installed at the bottom panel be enough?
3) Are the two fans located inside the monitor frame essential? could I disconnect them? (I will probably replace the stock monitor in the next month)
Thanks for your comments
1) No, you don't need them all operating.
2) Yes.
3) They are essential. If you disconnect them, the monitor will stop working.
If you replace the monitor, the one 120mm at the bottom should be fine. Since you're running a PC, you can always check temps to be certain.
I though that but I wanted to have a feedback from another user, thanks.
I successfully replaced it today and I will post some pics about it
By disconnecting them , monitor works but showing the alert OSD message. So, I found a good offer and I will replace the monitor in the next weekend ...however I will replace the two fans at the top of the cab maybe, just to have them in working order...
thanks for your feedback
WISE FWOM YOUR GWAAAAVE
So I swapped out my back fan (which was completely broken) with a Noctua NFP-12. It has a 4 prong connector but I basically just spliced the connector from the old fan onto the Noctua cable (while worrying I destroyed a $24 $16 fan in the process) and it ended up working just fine. Whisper quiet. I dont even think it was needed, since the fan that was there was broken and not even spinning, but the thing never gets too hot.
Though it does warm up my office when its on, thats likely due to the beefy PC I have in it. Pretty easy replacement for anyone that is not an experienced wiring guy. If I can do it, so can you :D
