Hello, I recently did a cap kit on a U200 in attempt to fix this odd static issue occuring with the monitor (which can be seen here). I did tbe recap, hooked it all up and then there was verticle colapse. Pulled it out again, went over possibly weak solder points, hooked it up again and the monitor began popping and making a static noise. All cables were hooked up fine and upon taking it out no capacitors or areas of the board were popped or fried. Is there anything I can do at this point or anything I should look into? Thanks!
