I recently purchased a midway cabinet that was converted to a sega naomi system. I would like to run a Pandora Box in the cabinet. Do I need to rip the Naomi system out? Can I use anything from It? Suggestions would be appreciated.
That big black connector plugged into the side of the green PCB is the JAMMA connector, you'll unplug that and then plug it into your Pandora's box. you can pretty much remove everything on that piece of MDF as that is all NAOMI hardware, the NAOMI Mother board, JVS Power supply, Sega JVS to JAMMA adapter, Sega NAOMI Audio amp and the Audo Amp Power Transformer.I recently purchased a midway cabinet that was converted to a sega naomi system. I would like to run a Pandora Box in the cabinet. Do I need to rip the Naomi system out? Can I use anything from It? Suggestions would be appreciated.
