hoagtech
Enlightened
Please I would love one with a good image if you have one or know of anybody.
Thanks
I'm located in Bellingham WA and can arrange freight.
Thanks
I concur. Do you not have one at all? Or is the one you have not performing well? If not performing well, then it is an easy fix. If it is dead, still a fairly easy fix. If the tube is burnt, you can swap it.Or just fix the one that you're having problems with instead of letting it go to waste by buying another.
He's the same gentleman with the Raiden cab from the other thread, I believe you posted asking for picsI concur. Do you not have one at all? Or is the one you have not performing well? If not performing well, then it is an easy fix. If it is dead, still a fairly easy fix. If the tube is burnt, you can swap it.Or just fix the one that you're having problems with instead of letting it go to waste by buying another.
I took it into an electronics repair and they recapped the pcb and the neck and replaced the fly back.What's wrong with the Raiden one? I bet you could get it looking great just by servicing the chassis, possibly rejuvenating the guns (donor tube would be even better), and then dialing it in.
I believe so:This will sound stupid but make sure your RGB cable is plugged into the chassis. I've forgotten to plug it in more than once.
