Realize this is old.
I have a parts saturn I am using to revive a ST-V that someone couldn't package worth a dang and killed the slave sh-2 in shipping.
Is there ANY disadvantage to me saving the second sh2 off the donor for a future cps3 cart?
I realize it isn't exactly needed but I do have it so...
All I need is a donor third strike pcb to have a multi if I swap the bios and by choice the sh2, right?
No Cd is the goal.
Ultra simms just speed things up?
For the SH2
Broadly speaking yes. The "custom" SH2 on the CPS3 security cart works perfectly for almost all use cases
Exceptions if you want to play 4th strike, then you need the "standard".
Swapping the SH2 chip over to play an unofficial variant of one game is a sweet technical trick and I'd love to do it, but probably not everyones cup of tea.
For the SIMMS
Ultrasimms are extremely awesome but also extremely hard to get - Maybe Darksoft might make more, but unless that happens I assume they are gone from the market. Being both awesome and irreplaceable, I cant imagine there are many willing sellers.
So that leaves you with Standard SIMMS which work with both SuperBIOS or the UltraBios
Ultrabios comes in 2 flavours, CD and NOCD
If you want to get rid of the CD drive entirely you'll first need to write the SIMMS with the CD bios, then swap the bios to the NOCD bios. Reworking TSOP is much easier than replacing the SH2 but given the value of the cart (moonbeams) and the number of swaps to accomplish this (four) there are a lot of expensive things that can go wrong.
So the best options as I see them are
1) A CD drive replacement - bluescsi is the easiest IMO
My assembly notes here, I have none to sell at the moment sorry
https://www.arcade-projects.com/thr...t-others-have-shared-bluescsi-for-cps3.23819/
2) A dual bios implementation
There is public dual bios project here from the awesome
@tovar
https://www.arcade-projects.com/threads/cps-iii-bios-and-cd-releases.36/post-416563
And I designed a helper board for that project here (the board is untested, use at own risk!)
https://www.arcade-projects.com/threads/cps-iii-bios-and-cd-releases.36/post-431433
