Let's start one of these as there seems to be interest in one. Hopefully everyone will contribute so we'll get a comprehensive list at some point.
For measuring the yoke, the tool that I use is the BSIDE ESR02 PRO. It seems accurate enough.
BSIDE ESR02 PRO- cheap tool recommendation
It's a really nice for this job, because it shows both resistance and inductance at the same time and keeps the values on the screen fixed for 15 seconds, which is enough time to jot them down or to snap a pic.
You can pick one up for around 20 USD. Remember to get meter leads for it.
Some specs can already be found here:
https://wiki.arcadeotaku.com/w/Yoke_Specifications
However, I would like to see additional info added to these.
The list will follow this format:
Monitor name (usually on a sticker on the frame somewhere)
Tube brand and model (sticker on the tube)
CRT base / neck connector (see here)
Chassis model (found on the PCB somewhere)
Yoke specs:
Hantarex Polo 25 25khz (from European Sega Rally upright)
Tube: A59EAK552X44
Neck: B10-277
Chassis: Hantarex Polo 25 25khz
Yoke:
Hitachi GMK-29 (from Jaleco Pony IV)
Tube:
Neck: B10-277
Chassis: GMK-29
Yoke:
Hitachi GMK-29FS2 (from SNK Neo 29)
Tube: A68KSA30X
Neck: B10-277
Chassis: GML MAIN P.W.B (?)
Yoke:
Nanao MS8-29 (from Sega Astro City)
Tube: Toshiba A68KJU96X
Neck: B10-277
Chassis: MS8-29
Yoke:
Nanao MS9-29 (from Sega New Astro City, Taito Egret II, + others)
Neck: B10-277
Chassis: MS9-29
Yoke:
Nanao MS-2930 (from Sega Blast City)
Tube: Toshiba A68KSM696X
Neck: B10-277
Chassis: MS-2930
Yoke:
Nanao MS-2932 (from Sega Naomi Universal)
Tube: Toshiba A68K**696X
Neck: B10-277
Chassis: MS-2932
Yoke:
Nanao MS-2933 (from Sega Blast City, Sega New Net City)
Neck: B10-277
Chassis: 05B20196E1
Yoke:
Sanwa 29e31s (from Sega Naomi Universal)
Tube:
Neck: B10-277
Chassis: 29e31s
Yoke:
Sanwa PFX (from Sega New Net City)
Tube: Beijing-Matsushita A68MAU085X90
Neck: B10-277
Chassis: SXD60910A
Yoke:
Tube: Toshiba A68LTF356X
Neck: B10-277
Chassis: KW0606A
Yoke:
Toei TC-L292
Tube:
Neck: B10-277 (?)
Chassis: TC-L292
Yoke:
Toshiba D29CR55
Neck: B10-277
Chassis: D29CR55
Yoke:
Toshiba PB7574-1 (from Konami Windy II)
Tube: Toshiba A68KZN696X
Neck: B10-277
Chassis: PB7574-1
Yoke:
Toshiba PF D29C051 (from Sega New Net City)
Tube: Beijing-Matsushita A68LZU185X
Neck: B10-277
Chassis: PD2367
Yoke:
Neck: B10-277
Chassis: PD1843
Yoke:
Neck: B10-277
Chassis: PB9929
Yoke:
Wells-Gardner K7000 25"
Tube: Label absent/unreadable
Neck: B10-277
Chassis: K7000
Yoke:
Wells-Gardner D9200 29"
Tube:
Neck: B10-277
Chassis: D9200
Yoke:
Wells-Gardner D9400 29"
Tube: LG Philips A68QCU770XV6L
Neck: B10-277
Chassis: PCBKT279410-04R
Yoke:
Yoke specs:
Lh | Lv | Rh | Rv |
for horizontal inductance in mH | for vertical inductance in mH | for horizontal resistance in ohm | for vertical resistance in ohm |
Tube: A59EAK552X44
Neck: B10-277
Yoke:
Lh | Lv | Rh | Rv |
0.31 mH | 4.82 mH | 0.7 ohm | 3.6 ohm |
Tube:
Neck: B10-277
Chassis: GMK-29
Yoke:
Lh | Lv | Rh | Rv |
0.25 mH | 19.0 mH | -- | -- |
Tube: A68KSA30X
Neck: B10-277
Yoke:
Lh | Lv | Rh | Rv |
0.36 mH | 19.0 mH | 0.8 ohm | 7.9 ohm |
Neck: B10-277
Chassis: MS8-29
Yoke:
Lh | Lv | Rh | Rv |
0.39 mH | 17.5 mH | -- | -- |
Neck: B10-277
Chassis: MS9-29
Yoke:
Lh | Lv | Rh | Rv |
0.33 mH | 14.0 mH | -- | -- |
Neck: B10-277
Chassis: MS-2930
Yoke:
Lh | Lv | Rh | Rv |
0.20 mH | 16.0 mH | -- | -- |
Neck: B10-277
Chassis: MS-2932
Yoke:
Lh | Lv | Rh | Rv |
0.20 mH | 16.3 mH | -- | -- |
Neck: B10-277
Chassis: 05B20196E1
Yoke:
Lh | Lv | Rh | Rv |
0.19 mH | 15.1 mH | 0.5 ohm | 6.8 ohm |
Tube:
Neck: B10-277
Chassis: 29e31s
Yoke:
Lh | Lv | Rh | Rv |
0.31 mH | 11.8 mH | -- | -- |
Neck: B10-277
Chassis: SXD60910A
Yoke:
Lh | Lv | Rh | Rv |
0.28 mH | 10.1 mH | 0.8 ohm | 7.6 ohm |
Neck: B10-277
Chassis: KW0606A
Yoke:
Lh | Lv | Rh | Rv |
0.28 mH | 7.47 mH | 0.7 ohm | 6.1 ohm |
Toei TC-L292
Tube:
Neck: B10-277 (?)
Chassis: TC-L292
Yoke:
Lh | Lv | Rh | Rv |
0.98 mH | 20.0 mH | -- | -- |
Toshiba D29CR55
Neck: B10-277
Chassis: D29CR55
Yoke:
Lh | Lv | Rh | Rv |
0.34 mH | 14.4 mH | -- | -- |
Neck: B10-277
Chassis: PB7574-1
Yoke:
Lh | Lv | Rh | Rv |
0.22 mH | 10.6 mH | 0.6 ohm | 5.9 ohm |
Neck: B10-277
Chassis: PD2367
Yoke:
Lh | Lv | Rh | Rv |
0.29 mH | 11.9 mH | 0.8 ohm | 8.2 ohm |
Neck: B10-277
Chassis: PD1843
Yoke:
Lh | Lv | Rh | Rv |
0.30 mH | 14.8 mH | 0.9 ohm | 8.2 ohm |
Neck: B10-277
Chassis: PB9929
Yoke:
Lh | Lv | Rh | Rv |
0.30 mH | 15.2 mH | 0.9 ohm | 8.3 ohm |
Neck: B10-277
Chassis: K7000
Yoke:
Lh | Lv | Rh | Rv |
1.48 mH | 22.0 mH | -- | -- |
Tube:
Neck: B10-277
Chassis: D9200
Yoke:
Lh | Lv | Rh | Rv |
0.248 mH | 5.89 mH | -- | -- |
Neck: B10-277
Yoke:
Lh | Lv | Rh | Rv |
0.29 mH | 7.82 mH | 0.6 ohm | 5.9 ohm |
