Did you find anything more about Cho Chabudai Gaeshi by chance?Anyone know if the table flip game is dumped? Looks like one ended over the weekend on YAJ:
https://archive.is/1MKAi
I passed on it as I don't have space for more Type X2s at the moment, and I've heard through the grapevine that it is dumped, but not released. I'm not sure how useful it'd be on the multi, anyway, given that you need the table, a 7300GS and probably some other specialized I/O.
do you have any info about this io? maybe the MegaJVS or other custom IOs could be made to look like the special IO this is expecting.it requires a special I/O to play.
Doubtful, I haven't gotten it logged yet,do you have any info about this io? maybe the MegaJVS or other custom IOs could be made to look like the special IO this is expecting.it requires a special I/O to play.
usually these are recognized as simply digital/button inputsthe table flip mech on it is a optical senor
most likely recognized as an analog input.also has a pressure senor on the top
in otherwords even if you could emulate it, recreating something similar with out making it exactly how it was made originally is going to be a clucky mess.usually these are recognized as simply digital/button inputsthe table flip mech on it is a optical senor
I'm not interested in trying to recreate something similar. I'm just interesting in knowing how it works and playing around with it; seeing what I can make the game do.in otherwords even if you could emulate it, recreating something similar with out making it exactly how it was made originally is going to be a clucky mess.
That 100%! Burst is awesome, but it requires such specialized equipment that IF you have it you likely already own the game.Dariusburst isn't useful for 99% of users (dual monitors, 2 Fast I/O's, etc). If you have a compatible setup, you probably already have the game.
I mean if you had an X2 with a Fast IO card and 2 Vewlix Side by side each with Fast IO boards that'd be everything short of the software needed to play it.That 100%! Burst is awesome, but it requires such specialized equipment that IF you have it you likely already own the game.
Need to do more,Card reader, the right side monitor image is mirrored/flipped, so you would have to correct that also. And to get full sound output working, you need audio amps from Taito most likely. Im pretty sure there might be some easy workarounds.I mean if you had an X2 with a Fast IO card and 2 Vewlix Side by side each with Fast IO boards that'd be everything short of the software needed to play it.That 100%! Burst is awesome, but it requires such specialized equipment that IF you have it you likely already own the game.
You need 2 fast ios, and the screen on the second viewlix would have to have a special inverter to play it natively due to the screen being flipped.I mean if you had an X2 with a Fast IO card and 2 Vewlix Side by side each with Fast IO boards that'd be everything short of the software needed to play it.That 100%! Burst is awesome, but it requires such specialized equipment that IF you have it you likely already own the game.
I did say "EACH" Vewlix would have a fast IO board, unless you're implying that there are 2x fast-io cards in the Type-X main board for DBEX?You need 2 fast ios
Or just mount the monitor upside down. They're rotatable and from what I've seen of the mounting hardware it'd be possible to mount it upside down.the second viewlix would have to have a special inverter to play it natively due to the screen being flipped.
that wouldn't work because it would still be backwardsOr just mount the monitor upside down. They're rotatable and from what I've seen of the mounting hardware it'd be possible to mount it upside down.the second viewlix would have to have a special inverter to play it natively due to the screen being flipped.
I'd be incredibly surprised if there wasn't an Extron box for that you can pick up for $20.that wouldn't work because it would still be backwardsOr just mount the monitor upside down. They're rotatable and from what I've seen of the mounting hardware it'd be possible to mount it upside down.the second viewlix would have to have a special inverter to play it natively due to the screen being flipped.
