The instructions for the CE version say to install the key writing wires. Reset is one of those wires. It is assumed no one is still using only decrypted sets with the CE multi.
No need to change PAL or Jumpers with the new kit.
Using a key writing wire injects the keys so it’s 1:1 the same as the original game. Decrypted has the protection removed.
If your board set doesn’t have a JST header you can solder directly to the CN header to get the keys written.
I’d highly recommend getting the write wire soldered as it also performs resets for you. If you can’t, though, just be aware that after a new game is selected and loaded you will have to power-cycle for the game to boot.I have the PCB ver: 93646B-3
I don't see a C-9 Header unfortunately. I do have a 2 pin CN8.
So where exactly would I solder which wires of the key writer?
And because I'm now soldering, Am I better off just loading a decrypted Romset?
I believe you. I'm just trying to get iteration on where and why..I’d highly recommend getting the write wire soldered as it also performs resets for you. If you can’t, though, just be aware that after a new game is selected and loaded you will have to power-cycle for the game to boot.
https://highscoresave.com/darksoft-cps2-multi-kit-champion-edition/ the install guide here has that info on the last few pages.I believe you. I'm just trying to get iteration on where and why..
What do you mean by that? I don't have ANY connector other than CN9Yeah you have the wrong cable for your revision board unfortunately.
If you can crimp yourself, things are easier.
Oh I see. NP at all though. I’m “heatshrink rich” ATM and plan on soldering each extension and shrinking all 4 with a wide heatshrinkYou still need the jst nh 6 way to connect to the DS board, so you crimp your own 4 cables that are long enough go reach cn2 a29-a32
Unless you're just going to solder directly from cn2 to the multi directly which you can also do
Xmen vs Street Fighter.You definitely need those sockets. What was your donor board?
Perfectly. We played it a good amount over Christmas. All Capcom roms too.Was it working before you installed the multi?
Well darn. Ill check my other XvsSF and donate the better case to this working board if it has CN6.
