There are no pals on the rom4 board, it’s all in an embedded custom chip instead I think. Pics on the first page of this thread here: Cyvern ConversionWhat markings are on your pal chips? It does it sound like your tsop chips are the issue is cyvern worked.
yeah, pattern playing ,i just copy the position or pattern of a good player while watching his play@ArcSys101 you 1cc'd Cyvern? crazy, both loops?
@ekorz My rom-3-board was originally a Gals Panic S Extra Edition, Japan region. I think there is no other difference between boards than latters have more memory banks to allow additional gfx roms could be installed, but if program code doesn't use them, board is completely equivalent as any other version.There are no pals on the rom4 board, it’s all in an embedded custom chip instead I think. Pics on the first page of this thread here: Cyvern ConversionWhat markings are on your pal chips? It does it sound like your tsop chips are the issue is cyvern worked.
Maybe I can use that mapper table to figure out how to turn an S-extra into sengeki, though it’s also a Korea board rom3.
@sergiopolog when you made that cyvern from a rom3 what region did it start as? And what region program roms and bios did it work with?
This. I also use the same eprom model as the ones originally installed (I think I erased them and burn new code into it... )
from recent efforts I believe my sengeki conversion is actually functional, just not on my Korea motherboard.I've also managed to pick up a Japanese PCB so I've taken some photos of the two of them and there are some differences.The korea PCB is missing 3 resistors below the capacitors, and the location of a chip to the right of the capacitors is different. I also find it interesting that the korean bios is labeled "GPS O/UB" while Japan uses "SKNSJ1". the sticker on the bottom has a different number on it as well.
On mine it looks like the two surface mount chips to the left of the unused BGA were replaced on the korean board. not sure if this is a "Fix" that was done or something that's common with korean PCBs.
korea:
Japan:
This. I need to use the multi bios in my korean motherboard in order to run properly the gameare you using the multi bios?
