ShllShockArcade
Would definitely start with swapping to the Tekken IMO. Will rule out the MiSTerCade then go from there
Whew, you had me worried. Be careful since you're working with AC voltage. I'd check the ground between your wall outlet and your AC stepdown converter first. Then from AC stepdown to your cabinet's ground. Then from cabinet ground to JAMMA harness ground. Should be 0VAC.Made a new thread for my issue. Like I said, in the end it did not have anything to do with MiSTercade.
https://www.arcade-projects.com/threads/blast-city-grounding-issue.28980/
I was thinking you should measure the AC voltage difference between your power strip ground and AC step down transformer ground. Then between your step down and cabinet chassis. They should all be 0V AC.
You're measuring between ground and hot which looks ok.
The issue here is that the Mistercade remote is effectively using DC ground as shield ground, and it's shorting to your cabinet's earth ground. Sega cabinets don't tie earth to DC ground, or when they do it's through a capacitor.
I have a hunch that you might have a short at your step down transformer.Ahh ok, yea those give 0V AC when I measured them.
I think the issue is this
MiSTercade mappings are now downloadable using the updater script. It has 100% of arcade cores mapped. This has taken many hours and is one of my favorite things about MiSTercade. I wish MiSTer had more sane mappings for arcade games, similar to what MAME has, but this is the next best option.
I haven't tested whether these overwrite existing mappings so back up your config/input/ folder before running.
Add this to your downloader.ini file then run downloader.sh or update_all.sh:
More info here: https://github.com/misteraddons/mistercade_mappings
My pleasure! I have "free play" mappings as well, that map Start as a secondary Coin button. Not guaranteed to work on all cores, of course. Let me know if there are regressions!Thanks for adding the mappings, @misteraddons ! It's really awesome to be able to hop from game-to-game with the mistercade and have sane mappings by default.
*yes*Am I using this thing right?
Are you sure?*yes*
Pictures you can hear. That game is a banger!Are you sure?
