[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.17-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1414 SMP Fri Apr 30 13:18:35 BST 2021
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] DMA zone: 2133 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 242688 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
[ 0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 root=PARTUUID=d9871c96-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 879832K/970752K available (9216K kernel code, 1311K rwdata, 2940K rodata, 1024K init, 860K bss, 25384K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 31910 entries in 63 pages
[ 0.000000] ftrace: allocated 63 pages with 6 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000024] Switching to timer-based delay loop, resolution 52ns
[ 0.000307] Console: colour dummy device 80x30
[ 0.001160] printk: console [tty0] enabled
[ 0.001229] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001288] pid_max: default: 32768 minimum: 301
[ 0.001516] LSM: Security Framework initializing
[ 0.001769] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001819] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003406] Disabling memory control group subsystem
[ 0.003544] CPU: Testing write buffer coherency: ok
[ 0.004038] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005280] Setting up static identity map for 0x100000 - 0x10003c
[ 0.005488] rcu: Hierarchical SRCU implementation.
[ 0.006413] smp: Bringing up secondary CPUs ...
[ 0.007579] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008846] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010182] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010340] smp: Brought up 1 node, 4 CPUs
[ 0.010394] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.010426] CPU: All CPU(s) started in HYP mode.
[ 0.010454] CPU: Virtualization extensions available.
[ 0.011435] devtmpfs: initialized
[ 0.028612] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.028898] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.028959] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.032176] pinctrl core: initialized pinctrl subsystem
[ 0.033359] NET: Registered protocol family 16
[ 0.037385] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.043116] audit: initializing netlink subsys (disabled)
[ 0.043431] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.044024] thermal_sys: Registered thermal governor 'step_wise'
[ 0.044967] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.045031] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.045313] Serial: AMBA PL011 UART driver
[ 0.065759] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.080153] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-04-30T13:47:07, variant start
[ 0.090172] raspberrypi-firmware soc:firmware: Firmware hash is d7f29d96450abfc77cd6cf011af1faf1e03e5e56
[ 0.139109] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.141663] SCSI subsystem initialized
[ 0.141946] usbcore: registered new interface driver usbfs
[ 0.142032] usbcore: registered new interface driver hub
[ 0.142123] usbcore: registered new device driver usb
[ 0.144044] clocksource: Switched to clocksource arch_sys_counter
[ 1.921271] VFS: Disk quotas dquot_6.6.0
[ 1.921417] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.921642] FS-Cache: Loaded
[ 1.921902] CacheFiles: Loaded
[ 1.932677] NET: Registered protocol family 2
[ 1.933685] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.933871] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.934019] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.934274] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.934468] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.934547] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.935057] NET: Registered protocol family 1
[ 1.935869] RPC: Registered named UNIX socket transport module.
[ 1.935904] RPC: Registered udp transport module.
[ 1.935934] RPC: Registered tcp transport module.
[ 1.935963] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.937607] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.941397] Initialise system trusted keyrings
[ 1.941677] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.951224] zbud: loaded
[ 1.953315] FS-Cache: Netfs 'nfs' registered for caching
[ 1.954275] NFS: Registering the id_resolver key type
[ 1.954345] Key type id_resolver registered
[ 1.954376] Key type id_legacy registered
[ 1.954561] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.955737] Key type asymmetric registered
[ 1.955770] Asymmetric key parser 'x509' registered
[ 1.955844] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.955884] io scheduler mq-deadline registered
[ 1.955915] io scheduler kyber registered
[ 1.960847] bcm2708_fb soc:fb: FB found 1 display(s)
[ 2.021416] Console: switching to colour frame buffer device 228x61
[ 2.050430] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1824x984
[ 2.054536] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 2.055514] bcm2835-aux-uart 3f215040.serial: there is not valid maps for state default
[ 2.057601] bcm2835-rng 3f104000.rng: hwrng registered
[ 2.058231] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 2.059306] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 2.071840] brd: module loaded
[ 2.084280] loop: module loaded
[ 2.085995] Loading iSCSI transport class v2.0-870.
[ 2.087837] libphy: Fixed MDIO Bus: probed
[ 2.088279] usbcore: registered new interface driver lan78xx
[ 2.088514] usbcore: registered new interface driver smsc95xx
[ 2.088706] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.817002] Core Release: 2.80a
[ 2.817120] Setting default values for core params
[ 2.817291] Finished setting default values for core params
[ 3.017812] Using Buffer DMA mode
[ 3.017930] Periodic Transfer Interrupt Enhancement - disabled
[ 3.018109] Multiprocessor Interrupt Enhancement - disabled
[ 3.018281] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.018483] Dedicated Tx FIFOs mode
[ 3.019333] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7504000 dma = 0xf7504000 len=9024
[ 3.019690] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 3.041819] dwc_otg: Microframe scheduler enabled
[ 3.041896] WARN::hcd_init_fiq:457: FIQ on core 1
[ 3.056065] WARN::hcd_init_fiq:458: FIQ ASM at 807be568 length 36
[ 3.070102] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
[ 3.084112] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.091251] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.098522] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 3.105813] Init: Port Power? op_state=1
[ 3.112921] Init: Power Port (0)
[ 3.120350] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 3.127584] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.134768] usb usb1: Product: DWC OTG Controller
[ 3.141906] usb usb1: Manufacturer: Linux 5.10.17-v7+ dwc_otg_hcd
[ 3.149042] usb usb1: SerialNumber: 3f980000.usb
[ 3.156967] hub 1-0:1.0: USB hub found
[ 3.164113] hub 1-0:1.0: 1 port detected
[ 3.172323] dwc_otg: FIQ enabled
[ 3.172337] dwc_otg: NAK holdoff enabled
[ 3.172349] dwc_otg: FIQ split-transaction FSM enabled
[ 3.172368] Module dwc_common_port init
[ 3.172746] usbcore: registered new interface driver usb-storage
[ 3.180105] mousedev: PS/2 mouse device common for all mice
[ 3.188647] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 3.198572] sdhci: Secure Digital Host Controller Interface driver
[ 3.205838] sdhci: Copyright(c) Pierre Ossman
[ 3.213560] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 3.221513] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 3.228990] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.238102] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.245773] hid: raw HID events driver (C) Jiri Kosina
[ 3.253218] usbcore: registered new interface driver usbhid
[ 3.260435] usbhid: USB HID core driver
[ 3.272620] Initializing XFRM netlink socket
[ 3.279935] NET: Registered protocol family 17
[ 3.287099] Key type dns_resolver registered
[ 3.294531] Registering SWP/SWPB emulation handler
[ 3.301488] registered taskstats version 1
[ 3.308403] Loading compiled-in X.509 certificates
[ 3.316136] Key type ._fscrypt registered
[ 3.322976] Key type .fscrypt registered
[ 3.329718] Key type fscrypt-provisioning registered
[ 3.348044] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 3.355172] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 3.364464] bcm2835-aux-uart 3f215040.serial: there is not valid maps for state default
[ 3.372396] 3f215040.serial: ttyS0 at MMIO 0x3f215040 (irq = 86, base_baud = 50000000) is a 16550
[ 3.380605] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.389635] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 3.396879] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 3.404579] Indeed it is in host mode hprt0 = 00021501
[ 3.486071] sdhost: log_buf @ (ptrval) (f7507000)
[ 3.496632] random: fast init done
[ 3.531225] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.540165] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.547243] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.557553] of_cfs_init
[ 3.564754] of_cfs_init: OK
[ 3.572710] Waiting for root device PARTUUID=d9871c96-02...
[ 3.576253] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.589873] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.624099] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.631268] Indeed it is in host mode hprt0 = 00001101
[ 3.723283] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.737193] mmc0: new high speed SDHC card at address aaaa
[ 3.745417] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 3.759479] mmcblk0: p1 p2
[ 3.796338] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 3.803571] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 3.809525] mmc1: new high speed SDIO card at address 0001
[ 3.874432] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ 3.881808] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.890070] hub 1-1:1.0: USB hub found
[ 3.897442] hub 1-1:1.0: 5 ports detected
[ 4.224133] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.238071] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[ 4.245515] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
[ 4.252757] EXT4-fs (mmcblk0p2): recovery complete
[ 4.274157] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.281455] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 4.299425] devtmpfs: mounted
[ 4.313432] Freeing unused kernel memory: 1024K
[ 4.321091] Run /sbin/init as init process
[ 4.328178] with arguments:
[ 4.328189] /sbin/init
[ 4.328200] with environment:
[ 4.328211] HOME=/
[ 4.328222] TERM=linux
[ 4.364501] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 4.371965] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.382178] smsc95xx v2.0.0
[ 4.736255] libphy: smsc95xx-mdiobus: probed
[ 4.744682] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:90:1b:e8
[ 4.985135] systemd[1]: System time before build time, advancing clock.
[ 5.044145] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
[ 5.089016] NET: Registered protocol family 10
[ 5.098191] Segment Routing with IPv6
[ 5.189961] usb 1-1.3: not running at top speed; connect to a high speed hub
[ 5.198324] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 5.216746] systemd[1]: Detected architecture arm.
[ 5.243580] usb 1-1.3: New USB device found, idVendor=1fc9, idProduct=0083, bcdDevice= 1.00
[ 5.252292] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.350603] systemd[1]: Set hostname to <RPi-Namco2X6>.
[ 5.374159] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
[ 5.541649] usb 1-1.4: New USB device found, idVendor=1997, idProduct=2433, bcdDevice= 1.04
[ 5.550659] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.560074] usb 1-1.4: Product: Wireless Receiver
[ 5.570136] usb 1-1.4: Manufacturer: Telink
[ 5.604880] input: Telink Wireless Receiver Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:1997:2433.0001/input/input0
[ 5.624814] input: Telink Wireless Receiver Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:1997:2433.0001/input/input1
[ 5.714623] input: Telink Wireless Receiver System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:1997:2433.0001/input/input2
[ 5.724441] hid-generic 0003:1997:2433.0001: input,hidraw0: USB HID v1.11 Mouse [Telink Wireless Receiver] on usb-3f980000.usb-1.4/input0
[ 5.745628] input: Telink Wireless Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:2433.0002/input/input3
[ 5.835364] hid-generic 0003:1997:2433.0002: input,hidraw1: USB HID v1.11 Keyboard [Telink Wireless Receiver] on usb-3f980000.usb-1.4/input1
[ 6.189448] systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
[ 6.232790] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
[ 6.358586] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.385536] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.395754] systemd[1]: Reached target Swap.
[ 6.417983] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.431497] systemd[1]: Created slice system-getty.slice.
[ 6.453719] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 6.476761] systemd[1]: Listening on Journal Audit Socket.
[ 6.499034] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 6.810080] i2c /dev entries driver
[ 7.531885] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.703010] systemd-journald[105]: Received request to flush runtime journal from PID 1
[ 8.336754] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.342175] mc: Linux media interface: v0.10
[ 8.345945] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 8.346017] [vc_sm_connected_init]: start
[ 8.351301] [vc_sm_connected_init]: installed successfully
[ 8.382781] videodev: Linux video capture interface: v2.00
[ 8.400533] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.417740] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 8.424705] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 8.434311] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.435272] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.448590] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.450072] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.456001] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.471599] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 8.472015] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 8.472362] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 8.472690] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 8.472723] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.472755] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.472779] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.472813] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.473010] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 8.541614] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 8.541683] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 8.562596] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 8.562664] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 8.572092] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 8.572160] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 8.927562] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 8.931472] usbcore: registered new interface driver cdc_acm
[ 8.931498] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 8.946491] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 9.198539] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 9.305109] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 9.313153] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 9.313550] usbcore: registered new interface driver brcmfmac
[ 9.345850] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.raspberrypi,3-model-b.txt failed with error -2
[ 9.547896] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 9.579879] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[ 9.580908] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 22 2019 01:59:28 version 7.45.98.94 (r723000 CY) FWID 01-3b33decd
[ 10.713110] random: crng init done
[ 10.713136] random: 7 urandom warning(s) missed due to ratelimiting
[ 11.781276] 8021q: 802.1Q VLAN Support v1.8
[ 12.044532] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 12.176357] SMSC LAN8700 usb-001:003:01: attached PHY driver [SMSC LAN8700] (mii_bus:phy_addr=usb-001:003:01, irq=POLL)
[ 12.176793] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 12.185300] smsc95xx 1-1.1:1.0 eth0: Link is Down
[ 12.220187] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 42.689394] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 43.994197] Under-voltage detected! (0x00050005)
[ 48.154191] Voltage normalised (0x00000000)
