Worth noting that while people have said it's too thin, it's the material that's too thin, it's not too small of a box dimensions-wise. The cardboard used barely keeps a box shape on its own :/.Thanks for feedback and sorry to hear that. I'll push them to get it changed asap.
Will do, once it arrives - Italian Cardboard is thicker for sure (not like the pizza dough which has to be the thinnest possible!)Someone That have bougth it from my site, saveyourgames.it can tell me if everything it's packed well?
Same here, although the colors look good, but the picture is smaller and way to the right.But yeah, when I put the Taito F3 in a cab, the color is often wrong and the picture is way to the right. Definitely the weirdest of boards when it comes to adjustments.
is this a digital CRT (with on-screen adjustments?) they generally have code to find the image boundaries and adjust accordingly automatically.In a B&O MX7000 RGB Television, the image is perfectly centered.
right, what I meant was if you have an onscreen menu that's an indication that the display is "digital", which also means that it probably has auto-adjustment capability with no input needed by you.The MX7000 can be digitally adjusted from the service menu yes. But I don't have to do that with the f3, it's just centered in the "default" setting.
Could you please tell me what settings you have changed to get the f3 working with the mini?F3 really messes with the OSSC scaler, in fact I couldn't get it working period.
xRGB mini is fine with it, and the Taito scaler has a preset for it (won't sync using other presets however).
I think as far as video modes go, F3 just has wacky front/back porch values (hence the strange centering on some displays and problems with scalers).
Interesting, I wonder if something like that would fix the screen shake I get on my older PVM using RGB out in 480i from my Gamecube.I'm using RGB's sync regeneration circuit (included on the HAS v3) with the F3 and xRGB mini.
I think that's the trick to stabilizing the shaky image, but I would have to go back and test (turn it off) again to be sure.
Yup same for me, I think this nails it then.forgot to mention before that the way I managed to use the F3 with the MX7000 is by setting the sync regeneration switch in the HAS.
