You can use a Capcom IO (or a bunch of other options) to run JVS stuff in a JAMMA cab.I feared that the price for Grand Master 2 will significantly higher already....
Other options might be to get a Taito Type X2 Multiboard with a standalone image...!? But that might required a JVS standard aswell.
The ebay board as selled already..... thats's too bad.
Any other options to get a running setup on ja jamma standard?
Capcom IO wont help you with the resolution mis-matchYou can use a Capcom IO (or a bunch of other options) to run JVS stuff in a JAMMA cab.
Hows the lag on this setup? Is it virtually the same as a Type X?honestly the easiest/cheapest way to run TGM3 in an astro would be to build a cheap PC with CRT_EmuDriver and a JPAC
I missed that we were talking about an Astro.Capcom IO wont help you with the resolution mis-matchYou can use a Capcom IO (or a bunch of other options) to run JVS stuff in a JAMMA cab.
