Regarding Jumpers:
The latest version of the instruction manual says "There is no need to modify the jumper configuration." Is this still true if my jumpers are in a different configuration than what's in the Walsdawg installation video? Or was that statement about not needing to modify based on an assumption that the jumpers would already be in the Walsdawg configuration?
I'm in the process of converting an Alpha 1 board, Rev 4. I just put on the wire from CN5 C13 to (G) PAL 9, and put in a G PAL (it originally had an E) but the Alpha 1's jumpers are not in the same configuration. The board was set up with the following:
1-4
S O O S
5-6
S O
8-13
O S S O S O
14-21
O S O S O S O S
22-29
O S O S O S O S
So basically I'd have to reverse the S/O on each of 10-13, 14-21, and 22-29. Not the end of the world, but a little bit annoying. So given the updated instructions saying there's no need to modify, I wanted to check before proceeding with the soldering/de-soldering to change the jumpers around.
Thanks!
