TylerDurden67
With this tutorial,you will be able to convert an nonnetdimmboard for Naomi to a new version which accept compact flash !
This is my latest technique found,the safiest,100% sure no brick !
My gift to the communauty
I take no resposability if you broke something and/or brick. This manipulation need solder skills !
Do it at your own risk !
Also, don't be fooled! Don't pay an expensive price for this!
In France, I ask for 35€ including shipping,and all is donated to my boy
For information,this is the kind of chip you need to solder:
You need:
- An Eprom programmer
Version 1
If you use your dimmboard flash rom(SHARP LH28F160S3T) you need an tsop56/dip48 adapter (if needed by your programmer)
Version 2
- an tsop48/dip48 adapeter (if needed by your programmer)
- one flash rom (ST M29W160EB70N6E or equivalent like Fujitsu 29LV160TE90PFTN)
- Solder (not glue,hein!)
- firmware 1 Here
- firmware 2 Here
- an netdimmboard
- an naomi
- all you need to send a file using netboot
- or ask "skilled" people to do it
(like mitsurigi-w or me for example)
The trick:
- Open your dimmboard
- Look at the flash rom to desolder at IC14/36
- Desolder it
Burn firmware 1
- Resolder flash rom
et voila! first step!
Now open your Netdimmboard and take rams and the daughter board.
Put it on your old dimmboard
Go to test mode and clear parameters.
Start your Naomi with your old dimmboard in it,and using net boot,send Firmware 2
Follow on screen instructions to burn it.
Congratulations,its an 4.02 dimmboard now!
Put rams and daughter board back to you Netdimmboard.
Put everything else on your nonnet Dimmboard and enjoy compact flash on it!
Good job,you made it dude!
Problem:
1 - If at start,error 22 comes,your flash rom is badly soldered.Resolder it
2 - If you are 3000% sure and still error 2,recheck your solder or even resolder again!
3 - and if it doesnt works?
- Maybe an buffer chip is dead,specialy an Fairchild.
change it.
look at the dimmboard, IC12S
to eventually change it
4 - and what if still error 22????
look number 2
Feel free to ask me help or questions about this,it will be a pleasure to answer you!
I can do the trick for you too,if you dont have hardware or dont want to it.
Merry Christmas to all of you !
You need:
Version 1
Version 2
- firmware 1 Here
- firmware 2 Here
- an netdimmboard
- an naomi
The trick:
- Desolder it
Burn firmware 1
Problem:
change it.
look number 2
