So I'm having an unusual issue with my SVGA arcade monitor and my Naomi. The naomi is working fine it has been tested with several monitors and my monitor is working fine and has been tested with several vga and svga sources. The problem is when I plug the naomi to the monitor everything works but the vga cable starts to heat up. I have been told that the original naomi vga cables were missing a few pins and that having all the pins was causing my problem. Could someone with an official sega naomi vga cable please tell me if there cable does not have all 15 of the standard vga pins and which pins are missing. This seems crazy but worth a try.
